ATF Unknown Change Record
Was paying attention to this at first, wasn't consistant over 26 qts of fluid for whatever reason. Same in same out would vary on stick had to adjust either way.
Always have to adjust but your close. The transmission fluid will go bright red. When its exchanged out.
Sealed transmissions can be done this way and its even easier because you can pull the high plug and pump fluid in until it starts coming out then make sure it's at the correct height at hot by simply pulling a plug with a container under it..:)
charlesz
