ATTN WRENCHHEADS: Answer my tranny problem... If you can! Sort of urgent
BRANFLAKE
2005 Toyota 4runner sR5 4wd 6 cylinder "World Series" closed tranny
Ok, drove aound alot the othe day in the hunded degree weather. Noticed the window in the back looked a little fogged but I thought it was from the heat outside and the super cold A/C inside.... anyways. I'm driving up a steep hill/ small mtn. I notice the transmission starts revving high and wont shift into the final (5th i think) gear. I start wondering WTF look all around at the gauges shifter etc. I check out my mirror and I notice smoke coming out behind the car. Luckily there was a pull off area on I-70 like right there. I pull over (still driving) and immediately look under the car and tranny fluid is leaking/pouring out from the drivers side, very bottom of the trans pan... A little hole that look likes it's supposed to be there because there is a little indentation, and a "check" cap/plug in the same position, on the other side of the transmission. So I am guessing this was the transmission "plug" hole that the fluid was coming out of. I probably lost another quart on the side of the road after I parked, and noticed the smoke was just from the tranny oil hitting the exhaust, and the cause of my slightly foggy window. My question, what happened? You think I just need a new plug and some new fluid? I hear filling these things can be a PITA itself. Any wrench heads out there that can assist me on this? Can I put the plug in, throw some fluids up there and see what she does? If so how do i get the WS ATF in there? It sits about 2 hrs away right now, I'm thinking dolly it home for now, then figure it out....? And by dolly/tow I mean disconnect the driveshaft before I tow it...
A little hole that look likes it's supposed to be there because there is a little indentation, and a "check" cap/plug in the same position, on the other side of the transmission. So I am guessing this was the transmission "plug" hole that the fluid was coming out of. I probably lost another quart on the side of the road after I parked, and noticed the smoke was just from the tranny oil hitting the exhaust, and the cause of my slightly foggy window. My question, what happened? You think I just need a new plug and some new fluid? Probably. It sounds like you caught very early. I hear filling these things can be a PITA itself. It's not hard at all... It is a bit 'tedious'. It requires a bit of patience and a fluid pump. There's a very specific sequence/procedure. It's outlined here: Welcome to Land Cruiser Owners On Line Any wrench heads out there that can assist me on this? Can I put the plug in, throw some fluids up there and see what she does? If so how do i get the WS ATF in there? Take some time and sort through this thread... It's about changing the fluid but has many great links, pics etc. IMHO, if you 4Runner is lifted a bit or you're a small stature guy you should be able to do it where you are. You may need to move it to level ground to confirm the fill is exactly correct.It sits about 2 hrs away right now, I'm thinking dolly it home for now, then figure it out....? And by dolly/tow I mean disconnect the driveshaft before I tow it...
See inserted text & links above, good luck!
As to "why" it happened. Any chance you had your oil changed recently? Someone accidentally loosening the wrong plug and not securing it properly when they saw red fluid coming out instead of black would be my first guess for how you lost your trans drain plug.
Toyota specs the drain&fill on the sealed trans at 2.1 quarts, IIRC. Adding that back should be enough to get you safely to somewhere more convenient to go through the full level check procedure if you can't do it where it sits.
-Brent
