Auto LSD and Stablity Coltroll Toggle
aeathb
I don't know if the other generation 4runners have a Auto LSD and a stability control toggle button, but I was wondering in which situations should you turn these off and on. I say this because today I went over to a beach to see how the v8 handled on sand. All I can say is "WOW" it has some drifting power. I got carried away and found myself stuck in the sand. When I get stuck, should I turn off the LSD? I found it wont let me drift without reducing power when the stability control comes on so I had it off. I eventually got pulled out, (embarrassing), but I never knew if I should turn the LSD back on, or just keep it off.
You posted in the classic t4r forum, most of us only have a inline 4 or at best the old 3L V6:( None of us have traction control that comes from pushing a button LOL some do however have a limited slip differential (LSD) but, most are not electric or air controlled.
The limited slip when engaged may have helped you out
I'm assuming a 2wd V8:confused:
You want it 'on' in scenario you described. When the button is off there's an Auto-LSD function that works in conjunction with other stuff including throttle control. If you try to get out of a stuck situation you'll notice the throttle seems unresponsive and slow. It may not let enough power through to spin the wheels or move the vehicle.
When the Auto-LSD button is pushed you'll have full control of the throttle to the point you can spin the rear tires.
LSD stands for limited-slip differential and refers to the systems ability to send power to the wheel with better traction. Without some type of limited-slip and one wheel on ice only the ice wheel would get power.
:cheers:
:cheers:
I agree. I own a 2wd SR5 and one time I was off-roading in some mud up hill and I got stuck I floor the pedal but my RPM's would not climb then I pushed the LSD button and rear tires spun and I slow crawled out of my problem. I think its there for "safety" on the road as when I wanna peel out it gives me no power and the rear brakes are on when off however yeah use your imagination. lol
