Auto transmission cooler lines need replacing
Champ
My transmission cooler lines are leaking at the juction between the hard lines and the rubber lines. Turns out its not the o-rings - the metal lines are corroded and have to be replaced. I have the new metal lines and transmission fittings plus a bypass thermostat and am going to bypass the radiator heat exchanger circuit with a separate cooler. Does anybody know if the metal send and return cooling lines from the transmission are above or below the normal trans fluid level? '99 Limited. Thanks
In other words, do I need to drain any of the tranny fluid before removing the cooler lines from the side of the tranny housing? thanks!
I would just drain it. You'll only be out a few quarts. Nothing wrong with refiling with fresh anyway.
If you have corroded lines you probably have contaminated fluid too. I'd do a self flush when I was finished.
Dropping Pan And Flushing Transmission
If you don't want to drop the pan just follow steps: 1, 2, 3 (only remove (2) front skid plates), 6 (ignore option), and 36 thru 44.
I did this last month by myself in about an hour and used 4 gal of Tranny fluid.
matisgugle
