You don't need to go to the dealer IIRC, check your manual. I think it involves some combination of switching the ignition on/off and holding down the lock or unlock switch....
this only applies to the limited using the outside door handle.
hmmmm....its on page 54 of my manual, for vehicles without smart key. The illustration also clearly shows the interior lock/unlock switch when describing the procedure...
For my 4th Generation...there's a way to do it yourself & have the doors remain lock when you put it back into P.Anyone know if I can get the auto unlock reprogrammed so it doesn't auto unlock when put in park?
The service writer is not a mechanic, he doesn't know anything but how to sell you services. the guy with the Techstream computer in back only looks at what the service writer has written down and then does it. I would print out the PDF, circle the exact settings you want, and then go back and complain until they set them all correctly.So I took it to the dealer on Sat and they did half of my requests. They turned off the auto unlock when put in park but he said the other option isn't possible. It is right below the other option on the PDF listed ITT (Opening driver’s door unlocks all doors).
Sorry, I was posting from my phone last night and didn't search first.
Thank you for the PDF. It had just what I was looking for.
Correct, and it's also in the 2011 manual, same page, 54, and includes smart key system, pretty simple too. :wink2:
wait, i'm confused dammit! So can i turn this stupid feature off myself or do i need to take it to the G D dealership?
You can turn it off/on yourself. Check page 54 of your manual (mine is 2011, might be different for 2010, but I doubt it)
alright. sweet. thanks for following up on this. yeah i got a 2011 too. I'll do this tomorrow. props to you!
