Auto window search
gledhill
Auto window switch
Does anyone know if you can purchase the driver auto window switch and install it into the location for the other 3 windows so that you have all the windows with auto up and down? Also the same for the passengers side, I wouldn't bother putting the switches in the back.
There was a thread on this a long time ago. I tried to use the search to help try to find it, but as what usually happens, you come up with nothing. Hopefully someone here will be able to get some info.
it will not work, trust me I did it. What will work is buying the DEI 530t. you will need two as each one works two windows only. one for the back two and one for the front passenger, but no need to hook up the drivers window unless you have a aftermarket alarm then you can program the windows to go up and down with your remote.
Anyways I installed these and they make your windows one touch up and down.
