Auxillary Lamp (Hella, PIAA, etc) uses?
trijicon
I'm planning on getting a set Hella Lamps but am not sure which one's to get. They have single fog beam, Euro beam driving, Single Euro beam, Pencil beam, and cornering beam.
What is common? what do you get? what should I avoid?
Here's the link I found
http://www.4by4connection.com/rallye4000.html
I plan on using it for the snow and extra bright light in dark situations.
Here's my take: You can't use one set of lights for what you want. For snow, you want lower wattage lights that aimed low- i.e. fog lights. For better illumination in dark situations, you want driving lights.
I would probably limit your choices between fog and driving lights. Driving lights are basically hi-beams, so they can be tough to use if other cars are in the area.
