Ok guys, I need a little help from the experienced ones here.
What are the implications to the GPV/ NAV function if I leave the parking brake signal disconnected?
The dimmer switch does not dim out the lights in the guages, but dims the light in the center console area. What could be behind that issue? I remember that the metra harness had an Orange-Black wire which did not have a match with Pioneer and I basically connected it to ground. Is that a problem?
Also, even though I have navigation map and my progress is tracked correctly, most of the options in the nav menu are grayed out. Is that normal for the begining?
Thanks for yoru help
