Axle Nut Size, not fitting
TXRick
Hey guys,
I've ordered a new axle nut from a couple of different places in town and they send me the same one that doesn't fit. It's supposed to be a 35mm right? That's what this is and it doesn't fit. I've even got three other axle nuts laying around...all 35mm..none of them fit. So, what am I missing?
why not just get it from Toyota, if the parts department doesn't have it, perhaps ask someone in service. I have one in my tool box, would let it go as long as I could get another.
Drivers side axle nut. Holds the CV to the hub.
They are all either 35 or 36, I've got several, but thats not the problem. It wont screw on...it's too small.
Why don't I go to the dealer? Well, we only have one Toyota dealer in town...
Long story short...they made my momma cry so screw them.
Is it an aftermarket CV? I used the nut that came with my Napa axle. I dont even know if the Toyota one will fit it.
Pic or two please.
I have to ask then what was holding the CV spindle through the knuckle in the first place?
If your threads are toast, buy a replacement CV.
I have reused OEM axle nuts on aftermarket CVs for years after I was tightening down an aftermarket cheap Chinese one on a Camry with an impact and it split inside the socket. And the OEM axle nuts fit both CVs from Napa and Oreilys for our 4runners.
So you are saying the THREADS on the nut are too small to fit the axle? Didn't the axle come with a new nut?
-Charlie
Yes, the threads are too small. I'm sure it did, but it has been lost to time.
Yes, aftermarket CV. I think it may have come from NAPA but not sure.
Pic or two please.
I'll post a pic tonight.
The axle nut was right? It's been lost...
Threads are messed up at the end but thats from smacking them with a hammer...I usually put the axle nut on when I need to smack them in but I have no working axle nut, so I messed those threads up...easy fix though so no problem.
I have 3 CVs and none of them will fit these nuts...deez nutz...lol
So, basically...I have put new CVs on in the past...several times...due to time and money the runner has been sitting. The CVs aren't the problem...everything was fitting and working fine when I took it off.
I think one reason you're having a hard time tracking down the right nut, and others often do too, is because you're sizing it incorrectly.
Nut and bolt specifications refer to the diameter of the thread, and the pitch of the threads, not the distance across the flats. Different types of bolts can have different head sizes, but thread dia and pitch will remain constant.
In metric, which is what's on pretty much any modern car, you'd measure the diameter of the shaft and then measure the distance between each thread. You can get special gauges to do that for cheap, but in this particular instance you'll probably be OK to measure off a 10mm section and count how many threads are in it. then divide that number into 10 and that's your pitch.
You'd specify it as (example, but probably close)M24x3 or M24x2.
M indicates Metric
24 indicates the thread diameter
3 indicates the pitch.
On an imperial bolt, it is similar, but instead of specifying the pitch between threads, you specify threads per inch. i.e. 3/8-16 (3/8 diameter, 16 threads per inch)
Once you have that info, it's just a matter of going to your fastener source and telling them what you need. For something as important as an axle nut, you're not going to want whatever they have in the bin at Lowes. You have to get the correct grade.
M indicates Metric
Yeah, that's what I am trying to say but in a simpler manner:)
I'll get out my mic and measure when I get home.
I figure the CVs are aftermarket so they might have a different nut than stock toyota. I know the CVs are aftermarket just not sure from where.
Any known aftermarket CVs that the stock Toyota nut will not fit?
I just measured the threads from what I believe was an OEM CV.
It was 27mm. I don't know the pitch.
I never checked to see if the nuts were interchangeable between the new axle and the one I swapped out.
When I installed new NAPA axles over the winter, I actually had to re-use the original nuts so that the threads had enough engagement in order to get the cotter pin through the castle nut.
OK well....after ordering from two different part stores, I just ordered a new CV...needed another extra anyways...
The nut on the new CV worked on all the other CVs I had laying around...not sure why I have 3 small CV nuts laying around and 3 nutless CVs...
Maybe it's the banging on the end thing that is the problem. It does not take much to mess up the thread-end or the nut or both at once on those CVs. It may look fine, but it won't thread. I learned the hard way, but I was able to repair the thread and use the original factory nut..
Correct way is to bang on a prybar held against the small flange on the inside end of the inner cage. That's the only way I do it now.
I am suggesting this because I don't want your new CV nut to suddenly not fit.
For the record, NAPA CVs use a 35mm just like factory and accept the factory nut.
Just for fun, take your "small" nuts (HEHE) and try threading them upside-down onto your 'nutless' axles. You may be in for a surprise. That is also a good way to repair the nut if you damaged the nut but the axle thread is ok.
seltzernator
