B/L question
Snookster
i want to add an inch or two. what all is needed with a 1 inch b/l from 4crawler? I want to add some height the cheapest way possible.... Thanks
Someone else can chime in for sure, but I believe the 4Crawler body lifts come with everything you need for the lift.
Hope someone answers your question for sure though, as I would also be interested to know.
Yep - that's all you need. If you get 2 inches you may need to extend brake lines and steering shafts. 3 inches for sure.
No that's not correct.
He sells the spacers, and an adapter for the auto tranny linkage if you need that.
Drop brackets for the radiator, extensions for whatever, are up to you.
A 1" lift shouldn't really need any of those though (except maybe the linkage adapter).
Thanks for the correction. I was thinking he sold everything as a package deal or you could buy it separate but I haven't visited that site in quite sometime.
1, 2, or 3" BL doesnt need any brake line extended. on auto tranny you would have to loosen the bolt and move the shift linkage. you will need a steering extension. i forgot if i used a radiator drop bracket or not on my 3" install.
