Back door window seal
Yotaway
I am trying to replace the weatherstrip on my 06 rear window. Can anyone tell me what the part number is for the outer weatherstrip that touches the glass? I am not sure if I need to buy the whole assembly of if I can just purchase the strip that is coming off. I found two part numbers on some other threads but I am not sure which one I need.
68290-35031
68291-35021
If anyone can anyone point me towards a diagram that identifies either of these part numbers look like that would be great.
Thanks in advance,
Brad
WEATHERSTRIP ASSY, BACK DOOR GLASS, OUTER 68290-35031 is exactly what you need. You pull out the old and slide in the new. Very simple replacement.
Does anyone know if the 4 side door belt moldings/weatherstrip are as simple to replace as the rear is? Having trouble finding much info.
Thanks,
Jeremy
Thanks baltieniterte,
I ordered all five pieces as the rear lift gate and the drivers door are in really bad shape. I will give it a try after they arrive and post back.
Jeremy
Thanks James,
For anyone else thinking of tackling this your self it was a pretty straightforward rip and replace. On the doors the weather strip is held in by sort of a j hook so it helped to put the window down and twist the old weather striping bottom toward the window a bit during removal. Install of the new was simply pressing it into place and reinstalling the screw, you will need a t-20 torx bit driver.
Jeremy
H.Sikina
