Back Up Camera problem
CuzzinOlaf
I posted in another thread about this, recently found out there is a TSB to replace the camera and seen that others have had this same issue.
Since then I've had the TSB for the camera done and now it is back. What is weird about it is that it only does it when I first start the vehicle or when it is really cold out. I've noticed that it does it more when it is cold and that 75% of the time it is fine when it is warmer out.
Has anyone else had this same problem or have a clue what could be causing it. I talked to the dealer and they said to drop it off again. If it doesn't do it for them they can't do anything. I'd like to tell them what I found out here before giving up the truck for the day.
Is the screen flashing when you put it in reverse some sort of code? It does that sometimes too.
What is a TSB? :confused:
