gkatmar said:I just noticed that the back window wiper is not working. Has anyone had this issue? I have a 2003 4Runner, it has worked in the past but nothing now. Thanks
qballjr13 said:Along the lines of the rear wiper but a little different issue...if you turn on the rear washer should the wiper go automatically like it would on the front wipers? I used mine the other day and I had to spray and then turn on the wiper to clean it off. Hopefully it was a one time glitch.
Mark86 said:Did you unplug the battery recently? If you did, you may have to reset the auto feature on your back window. If you don't do this, the sensor does not realize that the window is closed and the rear wiper will not work.
toto said:See this thread for instructions on everything you need to reset after disconnecting the battery, including the rear window.
http://www.toyota-4runner.org/showthread.php?s=&threadid=20637
