Bad day for me...backed into push button pedestal
RoyR
Didn't see it, and was going real slow...surprised at the damage.
Initial quotes indicate $1200 - $1500, they don't want to repair...suggest replacing the tailgate.
I can find a complete 2007 Tailgate for $1500, is this reasonable?
This is an 05 Sport Limited...
This is me uninformed on pricing, but as for a new tailgate, that price sounds about right.
I don't think that's your question though. You wonder if replacing the tailgate is a generally reasonable idea, right?
Again, I'm uninformed, but just shooting in the dark here: they are probably considering how much labor to do. To take off a whole tailgate is probably easier to them than disassembling the tailgate, popping that metal back into place (which, being metal that was already interestingly shaped, is tricky), and then finding some patch paint (if Toyota does that like I remember GM does?). Not to mention that their preference if they were to keep most of your tailgate would probably be to replace the broken part whole, i.e. the entire outer shell of the tailgate, which is basically replacing the tailgate anyway, since I think (more shots in the dark here) that part is not individually packaged..
If you don't mind so much, why do it at all? that dent is not so bad. Or, conversely, you could look into trying to pop the metal back into place and patch painting that spot yourself? A little janky, I know, but definitely less than $1500 cost for parts (and since you're doing labor, free for that).
You could also check a junkyard, although good luck finding a 4th gen (unless somebody totaled theirs), since they last forever..
My wife did some alteration yesterday as well.:censored: She backed into a parked car, and clipped the passenger side bumper cap. It doesn't look that bad. I should be able to unbolt it and then reassemble. It didn't look like the cap tore, from what I can see. It just suck when you get into a accident. As long as every one is ok.
Yep, it's a bummer...I'm to anal about my vehicles to deal with this, and I plan to keep this thing till it dies.
So, I bought that used 2007 Tailgate, and I hope to sell this mine for about $800.....hope the plan works, $1500 is a lot of diapers! :)
Deal fell through...the used one had cracked paint and 3 dings, that the seller did not advertise. And so the search begins!
Just take the inner panel out, Take the tailgate handle trim out, pop the dent out, sand it out, (maybe use some body filler if needed then sand again), then repaint. Easiest if it's white like it looks in the picture, since its a one-step paint process.
Go to your local Toyota parts counter and inquire about the cost of a liftgate shell. It wil be unpainted but flawless. Should be able to get one for between $600-$800. Get a paint shop to match the color, call some friends, buy some beer and swap over the inards! Voila!
Jhunt
