Bad gas mileage...O2 Sensor?
soundmanlpte
My MPG are down to under 16 mpg. This seems low to me. I've been considering replacing the O2 sensors as I am sure this has never been done. Could that cause the low mileage? Could a bad fuel pump cause this?
I'm no expert, but from what I've gathered from this site and others is the O2 sensor could definitely be the cause. There are several threads on replacing it on here and it's a pretty simple job. Just need a wrench (12mm or 14mm I think) and maybe some PB Blaster if the nuts are rusted. I think new sensors can be had for $50 or so. Make sure to get Denso.
If you not throwing a CEL than most likely the o2 is fine. But it could cause low mileage.
But again 16mpg is not bad gas mileage on this vehicle. Per Toyota a NEW 4runner v6 auto, 4x4 gets 15mpg city. 16mpg combined and 18mpg Highway. I dont see where your mileage is bad? I see you have 196k miles on your vehicle. I think your doing fine.
Cool thanks for the help guys. You may be right Jay. It may just be city mileage. However, I have averaged 19 and gone up to 22 with this truck. Also, Hayness manual lists O2 sensors as regular maintenence at 80k. And since it's so simple I will probably swap them out when I get some extra money. Can't hurt.
It really hurts to see such a big drop. I used to get 21.5 MPG on highways and now it is 17-18 MPG for no reason. replaced many parts and no improvement.
these days you get a gallon for like $2.40 right? Yey!
Gonzaga Lobos
