Bad Idle & Stalling
My 01 has had a quirk for a bit that I think is TPS related, dead/hesitation spot, leaving stop at 2-3 shift point speed.
Been waiting to see if code would set, going by posted you don't always get a code. Hhmm, wonder what set's the code.
[MENTION=115347]gamefreakgc[/MENTION], good thinkin with Vac. On the bright side not a problem finding 3 wire TPS not so with 4-wire year ago 1 place had them, guess it time to put it on.
This is exactly what I had pretty much and as far as I can tell on my little test drive yesterday it seemed like it was gone. Just replaced the tps.
Fixing the hoses and adding the fuel stabilizers helped but still idling low. 550 or lower sometimes when coming to a stop (feels like it's about to stall) and 675 in park. New TPS is still on order.
New TPS is in and runs even better, pretty much back to normal. I think in time the idle speed will level out even more.
So to recap, the #1 offender was indeed the TPS however it wasn't the sole cause. I confirmed it was failing slowly with the resistance test but I noticed in one of my dyno logs a few months ago the throttle position on my AEC said the throttle was at 103%. This should have been a red flag since it can't open more than 100%. I calibrated it about 3 years ago so since then the TPS voltage has degraded over time.
Replacing the IAC valve also helped the idle speed though it still threatened to stall a few times, though not as bad as before.
For extra measure, I did adjust the throttle stop screw. It's behind the spring on the bottom on the front facing side of the throttle body. I did one complete turn. For reference, there was 7 threads showing on the paint side so I turned it once to 6 threads.
EDIT: So don't mess with the throttle stop screw LOL. Idled at like 2000 RPMs! I put it back to where it was before and it's better now.
MaximussK
