TN4Runner07
I apologize but my old user name and email address were deleted so I had to start a new one!
*1999 4Runner SR5, V6, 200,000 miles*
Last week while driving home, I noticed a jerking at higher speeds. It was almost as if the car would not accelerate. Very weird. It happened at approx 50 mph around, 18-2000 RPM's. Although it never happened below that speed, it seemed as if something "clicked" to make it change over. The next day, it started just fine. No trouble until the engine became warm and I began to accelerate. Same symptoms. Shaking, lack of acceleration/to no acceleration, lots of jerking while trying to accelerate (putting pedal to the floor!!!), rough idle and feels like it wants to move forward while sitting at a stoplight. I noticed that the exhaust was very loud as well pulling into the neighborhood. No smoke, no burning smells, no overheating. Oil and coolant are at perfect levels. None of these symptoms began until the initial jerking occurred. IE nothing happened until the engine was warm and I started to accelerate! Very intermittent. Then it began and didn't stop until it either sat over night or cooled down. Again, no change in engine temp/oil pressure, etc. Changes/shifts gears great with no hesitation or "hard shifts". The next day I checked the codes and TPS came up along with multiple misfires in different cyc. A mechanic friend suggested that I just replace the TPS. The misfires were not actively coming up as one of the codes, the reader had said that they were "pending". I replaced the TPS sensor and it didn't help at all. I even put some seafoam in to see if it was possible a clogged fuel injector. No improvement. Of note, all new NGK plugs and wires were installed last year as well as a new MAF. I have replaced the TPS sensor, checked the spark plugs, cleaned the MAF, cleaned the throttle body and added just a bit of oil due to it begin slightly low. I apologize if a similar thread like this has been started, but I thought some of these symptoms didn't match others.
Any experiences with this? Suggestions? Thoughts? Any help would be very much appericated! Thanks!
