BajaRack Utility Rack W/ Awning- Mount options
Haydenatx
Member
Hey folks,
I have a flat utility rack on my 2015 Trail and recently purchased an ARB 2000 awning. I am looking to mount it to the bajarack in the most cost effective way, preferably with a universal type mount that will work with possible other vehicles in the future. The Gzila is currently my top pick but I found this Rhino one. Please forgive me if this is already a thread, but I didn't find anything in search results.
Does anyone know if the channels on the ARB are the same as the Rhino sunseeker?
Rhino-Rack - Foxwing ARB and TJM Bracket Kit - Rack Outfitters
Hi- the ARB awning vs. Sunseeker or Foxwing is a tad different. You'll need to drill an additional hole on this bracket you posted, to make it fit within the channels. Easy task, if you have a good drill and sharp metal bit.
The ARB is much shorter in location between, as where the Sunseeker and Foxwing holes sit a tad taller... Best of Luck!
About to have the exact setup, was wondering what you ended up doing for mounting your awning?
Hey folks,
yup, the rhino mounts work on the bajarack. I have the same rack, mounts and awning. No drilling or cutting required. You do need to go to home depot and buy some nuts and bolts though because the kit does not come with it.
I went with the Fourtrek mounts for my Baja Utility as well, only because the gzila ones are never in stock and the dude is impossible to get ahold of.
The Baja mounts place the awning to high for my liking, It looks goofy imo.
Here is a photo of the Fourtreks.
youngrk
