Ball joint replacement
TrexRunnerGirl
Now for my last question today. Has anyone used this ball joint type from GES Parts?
tem specifics
Condition: New Brand:
GES PARTS
Surface Finish: Premium Quality Manufacturer Part Number:
K90262 (1) K90263 (1) K90681 (2)
Warranty: 1 Year Interchange Part Number: EV433 (2) ES3547 (1) ES3548 (1) K90255 (2) T3548
Kit Parts Included: Ball Joint, Inner Tie Rod, Outer Tie Rod, Sway Bar Placement on Vehicle: Left, Right, Front
I know I need to replace the CVs and ball joints; also the struts/springs/shocks but thought I'd do the CV/ball joints first. then the others.
I need to learn to take baby steps just don't want it to break down before I get her all fixed up.
Many thanks to all for tolerating me and my questions.
tem specifics
GES PARTS
LOWER ball joints is one component that calls for genuine Toyota OEM 100% of the time IMHO.
I can buy them from the dealer and install or let the dealer do it correct?
most people would agree you can get the best deals online if you know exactly what you need. You should strongly consider attacking your Lower ball joints first as the main priority...
Tim & I like to use camelback toyota https://parts.camelbacktoyota.com/partlocator/index.cfm?siteid=214329
PN: left lower ball joint (43340-39465)
right lower ball joint(43330-39585)
you will also need 8 new bolts & locktite!
Thanks again. I would need someone to help me since this is the first time I'd attempt anything like this. I may need more muscle than what I have.
I need some locals to reach out to for help and assistance. I have no problem getting down and dirty fixing stuff. :) I'll even buy the beer!
[MENTION=120071]mtbtim[/MENTION] has a video that will give you all the confidence you need, and a long, 30" breaker bar is your friend!
The bolts for the ball joints to the spindles on 96-00 are PN 90080-10066 (qty 8)
Good luck!
It's a very straight forward job. Perfect one to being to get your hands dirty on. Get a C-shape puller. Will make the job a lot easier. Another tip is that when you're tightening the 4 lower bolts on the ball joint, tighten them, lower the vehicle down to the ground and then torque them. Don't torque them while the vehicle is in the air.
The bolts for the ball joints to the spindles are PN 90080-10066 (qty 8)
Good luck!
if I'm not mistaken, those are the bolt part numbers for 4runners ranging from 1996-2000...
01-02's have slightly different bolts.. the part number for the lower ball joint bolts for a 2001 & 2002 4runner is
PN: 90119-10933
You have that backwards. Torque it while the joint is unloaded otherwise you WON'T be applying the proper torque to the bolts! LBJ is under tensile forces when loaded.
Interesting. I've always heard the opposite with the LBJ's. As well as I've heard of several people over-pressing the boot when trying to torque the bolts while in the air.
Good luck!
You know, I don't what's up with that kid I work with, [MENTION=102606]infamousRNR[/MENTION]. He had an opportunity to plug one of our videos and he dropped the ball. I'm going to have to have a talk with him. Maybe he just didn't want to steal my glory since he knows how much I like posting our videos when the opportunity arises.
PN: 90119-10933
Didn't realize the bolts were different. [emoji51] Updated my post to be accurate and more clear. Thanks and plug your vids [MENTION=102606]infamousRNR[/MENTION]
Sent from my Nexus 5X using Tapatalk
Also, the bolt information is in our video description. See, if [MENTION=102606]infamousRNR[/MENTION] would have just plugged our video and said the bolt part numbers were in the video description, he would have killed two birds with one stone. I'm going to have to sit him down and have another class on Video Promotion 101.
uh oh... looks like I'm on time out!!! :redface:
I was going to post the video's we've made in the next response but then i had to leave the house to run some errands. :shrug:
without explicitly saying it, i was trying to get this newer T4R member "runner girl" to do some searches before starting new threads
Give a girl a part number and she'll shop for a day, teach a girl how to search the forums and she'll shop until she drops. Lol
Please don't block me [emoji51][emoji23]
I feel ya Bra. Luckily she came to this forum because we tend to be more forgiving and helpful here.
OP, what my buddy Sean is saying is it's good to do a Google search first because there's a very good chance there's already multiple established threads on this forum and others so you have a good chance of finding your answer without having to resort to starting a new thread. It's usually when you've exhausted your search and still can't find you answer that you start a new thread. The search engine on the forum is ok but using Google is a lot better.
This forum is a wealth of information and there's lots of very knowledgeable people generous with their time that are willing to help you out. Welcome to the club!
Lol there ya go!
I’ve looked and watched videos but needed more of a parts list. I still need a buddy to help me.
I do the GORUCK events and can carry heavy stuff but as for wrestling tires and stuff, yea I need a hand.
@ TrexRunnerGirl- Depending on the year of your 'runner, you could possibly be eligible for the LBJ recall and have Toyota install new LBJ's and pay for the whole thing. It's worth a trip to the local stealership to find out.
Laredotx
