Ball Joints and questions
MrCooper
I have a few questions
1. One of my lower ball joints is starting to bleed. I need to know if you can change them or is it a situation where I have to replace the whole control arm and if I can change them is it just as simple as any other vehicle
2. I just installed a 2 1/2 inch lift and went to from OEM size to LT275/55R18. Is there any issues I should concern myself with when it comes to these oversized tires as far as the hubs.
Any help will be greatly appreicated
They can be replaced without replacing the whole control arm, but it isn't easy. My 12 ton press wouldn't budge them when I tried it.
They have to be pressed in and out. I used a small 2 ton bottle jack, the master press kit from advance auto, and a propane torch to get the old ones out. They rust/weld themselves to the bores. Get ready! They launch out with a pop and make me jump everytime.
H.Sikina
