Ball Joints and Tie Rods
larrylegend
So I just finished doing my inner/outer tie rods and lower ball joints on both sides of my 99. I got everything put back together and now my brake light on the dash flashes intermittently. It seems like one of my brakes is dragging a bit. I have no idea why it would be dragging as I didn't mess with the brakes at all. I only drove it up and down the driveway so I wasn't able to get enough speed to see if it was pulling one way or the other. I also haven't had an alignment done yet. Any ideas?
Up and down the driveway won't tell you if it's dragging or not. (Unless you have the coolest driveway in the world.). My guess, check the ABS/vehicle speed sensors. Check the brake fluid level too to be safe.
Well the "driveway" is about 300-350 yards long so I was able to get up to about 30mph. I will check the sensors tomorrow morning. Also, if it matters I have my ABS disabled at the moment.
Lift it up and spin the wheels to check?
Did you end up going all OEM for parts? I know for sure I am going OEM for LBJ but cant see myself spending $250 for OEM Inner tie rods.
30mph on your driveway? wow. That's more of a runway. AND, that's pretty cool.
Nothing more I can add. carry on.
Yea I went all OEM. I figured the original parts have lasted for 150k miles so these new parts should last about that long too. I don't really want to have to do these again anytime soon.
So my brake fluid was right at the low level mark. I filled that up a bit. I took my wheels off and brake pads off. I also pulled my dust shield back a little bit. I put everything back together and so far it drives like it should and no brake light.
So I am still not sure exactly what caused the brake issue. I can't imagine the brake fluid level causing the brakes to stick. The brake pads are good on both sides and the brakes were bled not too long ago.
Just curious about the ride after the tie rod and ball joint replacement. Any significant improvement? I got the 60-70 mph shakes and some suggest that replacing these parts helps.
Well I just got back from my alignment. The truck drives like it is brand new now. The front end is so much tighter than it was, especially over bumps. I haven't had the chance to get it on the highway and get over 55mph yet but so far I am very happy with it. I also still have the poly bushings for the steering rack and new rack guide that I can install to hopefully make it even better.
Completed the inner/outer TREs and LBJs this past weekend. First side was slow. Second side much easier. After wheel alignment, truck drives tight. But still have vibration between 65-70.
I think my old parts still had life on them. A couple of the joints were a little stiff but no play.
Jesse1
