Banana Holder NOW AVAILABLE
Do you need somewhere to safely store your banana?
  • Yes, I don't want my banana on the floor or in the glove box.
    Votes: 151 85.3%
  • No, I don't like bananas.
    Votes: 26 14.7%
  • Total voters
    177
Just got mine last week! Heavier than I thought they'd be! Looks like they'll hold up well...should get to the install sometime this week and will post some pics!
-H-
Oh cool.. thanks for clarifying!
Regarding my earlier question about a CB or HAM mount, I should have been more clear. I meant that if I would be able to mount the PTT handle of a cb/ham
Similar to this:
Yeah definitely! They make lots of mounting options for them, some may just snap/clip-on, others you may have to drill into the panel or sandwich to the panel with a backing plate or washers. I'm sure you could also find a MOLLE style holder for one.
Have been looking through the inter webs for hours to find a molle mount and no luck. Anyone have any recommendation or links?
Do you have a CB yet? It may or may not come with a mount. Usually, they use mounts like this. You could either drill into the panel and bolt it on or sandwich it to through the MOLLE holes with washers or a backing plate.
I dont mind drilling into the Molle, I just dont want the screw on the otherside to rub agains the center console thus why i would like a molle stule mount
molly was a bad girl
I tried to stick my banana in molly but she was having none of that.....so I added a triple shingle for my miscellaneous stuff.
I can still stuff a banana in there if i want, or phone, or, cb handset, or knife or kleenex or whatever I want to....and folds relatively flat when not in use (driver side shingles not in use atm)
Good thinking victory4x4
Has anyone tried to move their seat up and back since the install? Just thought about this yesterday as i lose something between the divider and the seat.
Got mine and have only installed the drivers side so far. I dig it. 5.11 molle pouches fit great and tight. Flashlight, karambit, banana and CB all loaded up.
Just got mine today. I thought i would need to screw from behind but the instructions on the vid do not show that. Would it be strudy enough to held a 32oz water flask or do you recommend bolting from the back?
ThankS!
Pretty happy with my setup. Took 10 minutes to install. I didn't bother drilling. I just started screwing it in with force and the screw tapped itself.
Great product!
ThankS!
Would probably depend on how far it hangs out off the panel, that could be a lot of weight/leverage on the trail. You may want to just try to install like the video and see how sturdy the water seems while the truck is stationary first. It may be just fine.
MaximussK
