Bandit Runner's Custom Snorkel Build
Bandit Runner
Senior Member
Well, I've been working on designing and building a custom snorkel for quite a while now, so I thought it was finally time to post my snorkel build. I am too cheap to purchase a Safari Snorkel, plus I really enjoy designing things from scratch in CAD, and building them.
The first thing I needed to do was create a model of the truck. This was no easy task, as the sheetmetal has many complex curvatures. So what I did was to cover the A-pillar and fender with blue painters tape. Then I marked and labelled about 200 points on the tape with a marker. Then I painstakingly measured each point in 3 dimensions (X, Y & Z).
Then I was able to create each point in CAD. I joined the points with curves, and then created surfaces from the curves. This is what I ended up with.
Now I could finally start designing the snorkel. I started by going to Lowes to find some parts to use. In the plumbing section I found several parts. A 3" elbow mates to the opening of the airbox perfectly. Then a piece of 3" PVC pipe mated to the elbow and travels above the wheel well to the fender opening. I also found some 3" rubber clamps to connect everything and be air tight. I also ordered a piece of 3" aluminum tube with 1/16" wall for the tube going up along the A-pillar.
Then I modeled all these parts in CAD. Next, I created the path for the airflow. I tried to keep it nice and tight up against the truck, so it wouldn't stick out too far. These pics show the purchased parts and the airflow path.
The basic concept is similar to the Safari Snorkels. Next, I modeled the component that mounts to the inside of the fender, and connects to the PVC pipe. Then I modeled the component that mounts to the outside of the fender, and connects to the aluminum tube. This pic shows them without the fender. The green is the inside part, and the orange is the outside part. Pink is the PVC pipe.
To put my own spin on the design, I wanted the head of the snorkel to look similar to the truck's hood scoop. This is what I came up with.
Looking from the side of the truck:
Looking from the front of the truck:
From underneath:
More to come.
Awesome Bandit!! Some seriously sick ingenuity right there... things like these make me appreciate this forum. Sub'd and also wondering when your taking orders?
You know you should always make two of something when building something from scratch. I'll take the other one.
actually i think 3rd is the best number so that other one i would happily take it and add it to mine :naughty:
but to Bandit Runner, sweet job, i love playing with cad and designing all this stuff too
i'm gonna jump on board here and say if you can produce this for about 150 EVERYBODY is going to buy them. a while back, CJ80cruiser tried to put together a group buy and it died a horrible death. main arguments were the over all cost of the snorkel + shipping. that being said, if there's anyone on here that could have produced their own, it's definitely you! go get em bandit.
Thanks for the kind words everyone. Sorry, but there won't be any production quantities available. This will be a custom one-off assembly. There is a lot of custom work involved, and when it is complete, I will have put a couple hundred hours into designing and building it.
To answer a few questions:
Sweet! You should keep us updated on total cost. I'll bet its a quarter of what safari is asking
Total cost for me is only going to be around $50. The aluminum tube was the most expensive part, and then a bunch of little parts from Lowes.
How did you measure the Z axis on the body panels...?
I figured this would come up. What I did was to park the truck inside the garage, parallel to the side wall of the garage. This took some trial and error, but eventually I got it just right. Then with the use of various levels, squares, tape measures, and plumb bobs, I measured each point to the floor of the garage (Z), the front of the garage (Y), and the side of the garage (X). I'm sure it isn't perfect, but close enough.
I wounded if you could have parts 3D printed, make plugs and have some molds made and pop out a few parts.
I have access to several rapid prototype machines, that can basically make any part out of ABS, polycarbonate, or nylon. The custom parts I designed will all be made from the FDM (Fused Deposition Modeling) process, and will be made from polycarbonate. No molds will be made for the custom parts.
I like what you've shown us so far. How far along are you and what's left? Can't wait to see more.
Glad you asked. Basically I have everything on the inside of the fender figured out and completed. This includes the PVC elbow, PVC pipe, and the custom interior piece that mounts to the inside of the fender, with all the clamps. Here’s a pic of that sub-assembly:
Here are a couple of close-ups of the custom interior piece:
Here’s a pic of the sub-assembly installed inside the fender. (You’re looking straight up into the fender well.)
I am currently in the process of having the custom exterior pieces built.
REE
