BaseRunner
Sooo...they installed the O2 sensor into the manifold? I'm just asking because I can see an exhaust system in my future. The cat thing was stalling me. I guess a competent exhaust shop could weld a bung on a new cat.
I went out and took some pictures for you, hopefully this helps ya. My o2 sensor was so badly rusted on, the shop had to cut it off, and weld it onto a new pipe onto the manifold im guessing.
I just saw on Chuckles thread you are wanting to change to mouse ear mirrors.
They will fit the top holes. If you pull off the interior door panel you will see where the factory made the mirror holes. The inside has an extra section of metal welded on to make it more sturdy. I measured the holes on my 4Runner, the holes on my tow mirrors and the holes on some mouse ear mirrors for a guy a while back and they were all the same measurement. Center to center the holes should be 2 3/4". There's a discussion here:
Compatible Mirrors - YotaTech Forums
^^Discussion is about pre 1984 trucks but the measurement on the newer style black plastic is the same. 2 3/4" oc.
I can confirm this. I changed from plastic mirrors to tow mirrors and the top holes were identical.
So in short, I have to pull off the interior panel and then go from there? or can I just take the screws off from the outside?...stupid question I know....thanks for the help though I really appreciate it!
