Battery/Alternator Problem
golfman44
So I'm running a 12" W7 from a 1000/1 amp, so with the install I had to get a new battery to support it all...got a optima yellow top battery with 0 gauge wiring to the amp. anyways everything was runnign awesome....but when i did the install (did it myself) when i went to pick up the battery the guy mentioned I would most likely need to get a new alternator soon as the battery wouldnt be supplied enough by the stock on my 99 4runner limited. Anyways Now the PDB only read around 12volts with the system turned off, before it was well over 14volts. Also, the amp shuts off as a self-defense mechanism because it detects low voltage (it does this when it drops below 10volts) so I just have the system disconnected right now. Another probelm suggesting that its poor power supply is that the volume of my stero while playing music is really low, ilke before volume 20 you couldnt hear the person next to you, but now it is about half as loud. Anyways, I'm taking it in for its major in about a week so ill just have the mechanics look at it but I'm just curious if it could be anythign else? thanks!
