Battery Light started blinking then the car died and now car won't start!
robaroni
Battery light blinked on and off a couple times last week. Had the battery tested and checked all of the connections for corrosion. Everything was good.
Then yesterday the battery light went on and stayed on. Now I don't have enough juice for it to turn over.
Probably the alternator right? :cry2:
12.7 battery Voltage while everything's off?
What voltage are you getting while truck is running?
On earlier gens it should be from 13.5 to 15.1 Volts. Outside of that, most likely a bad alternator OR connections to it.
I had the same problem october 2016, I place the alternator with a toyota REMA and problem solve
