BBQ/Smoking Meat
Those look awesome! Did you do any rubs or just the sauce?
Thanks. I just season with McCormicks Montreal Steak Seasoning then cook until 95% done... cooked but a bit tough. Then toss in sauce and back on grill to get tender and crispy. They're the best I've ever had and I eat wings all over the country.![emoji41]
Doing the same deer as before tonight.
I'm doing pressure cooker short ribs tonight per chowhound.com
Be jealous, be very jealous
Sent from my Nexus 5X using Tapatalk
Be jealous, be very jealous ��
Technically... :offtopic: :D
Barbecue (informally barbeque, BBQ or barby/barbies) is both a cooking method and an apparatus. The generally accepted differences between barbecuing and grilling are cooking durations and the types of heat used. Grilling is generally done quickly over moderate-to-high direct heat that produces little smoke, while barbecuing is done slowly over low, indirect heat and the food is flavored by the smoking process.
Per chowhound recipe with a few variations
English cut short ribs braised in the pressure cooker, fries and oven roasted, garlic-tossed Brussels
That's like boiling your ribs before you put them on the smoker....not real bbq. Looks good, but definitely not in a bbq class.
All those in or near the DFW area need to try heim BBQ off of magnolia in Fort Worth. On oar with Franklin's in Austin
Sent from my HTC One M9 using Tapatalk
Made my first thing on the new replacement Brinkmann, and the ribs came out fantastic. After I butchered them and removed the membranes I decided to cut them before doing the rub because it's always more of a pain to cut them the next day.
IMG_20160818_235838540_zpskqyg7tdd.jpg~original
Applied the oil and rub the night before to let them set over night
IMG_20160819_241354274_zpsdkfdh4m4.jpg~original
Here's the next day as they're getting to room temp
IMG_20160819_151837728_zpsssnbxnvo.jpg~original
I ended up doing the 2-2 method and they were some of the best ribs I've ever made. Here's after 2 hours of smoke when I wrapped them and threw them back on
IMG_20160819_180653771_HDR_zpsisymgdty.jpg~original
New smoker smoking away, didn't realize the lid was crooked before I took the pic*
IMG_20160819_180719561_HDR_zpsw8ingspy.jpg~original
And here's the finished product, bones are completely clean and that smoke ring :high5:
IMG_20160819_202058294_zpsggsiars4.jpg~original
Having them again for dinner tonight :thumb3:
Sous Vide
I know this topic may be considered blasphemous by some - but has anyone here used the sous vide method?
There are recipes for doing brisket using the sous vide method - here's one:
Sous Vide Smoked Brisket Recipe | Serious Eats
This recipe intrigues me because it still allows for the use of an actual charcoal grill with real smoke to "finish" it off over a couple hours, while letting the bulk of the cook time take place unattended in the sous vide water bath.
FWIW I do have an Anova Culinary sous vide cooker and I've used it a bunch of times to prepare things like lamb chops and, on occasion, steaks. Not everything has turned out awesome but for the most part I've never had a bad meal using it.
Smoking brisket is definitely an art and takes a LONG time. This method is intriguing but I know nothing about it since I'm just an old school charcoal smoker guy
Sous vide sounds interesting and I'll anything once (short of toilet wine or grabbing my ankles) but I can attest to smoking a brisket as being an art form.
My best advise with brisket is to use the point or use the deckle but I avoid suing the flat alone when cooking for long periods of time. My best results smoking brisket were done using the deckle, though many will argue it's not brisket, no one will refuse to eat it. Substitute deckle into any smoked brisket recipe and watch the crowd go wild.
I might try the flat by itself in a sous vide preparation and finish on the smoker to get that hint of smoke - someday.
If and when I attempt to cook a brisket with sous vide you will all be the first to know. I just need to come up with a proper occasion - even with sous vide we're talking about 48 hours worth of commitment before mealtime.
No pics but last night I grilled up some top sirloins (from Costco) on my Weber gasser. 3:30 per side on direct high heat and they came out perfectly - 133F, just about spot on medium rare. I seasoned with salt, pepper and fresh chopped rosemary. Sides were quinoa and brussel sprouts (also prepped on the grill). Wine was a 2010 Maddalena Cabernet Sauvignon (Paso Robles).
I'm down in OC - and I'm a member of Halter Ranch in Paso. Love that stuff. I think the bottle I drank last night I found at Costco, though :)
johnnya
