BBQ/Smoking Meat
Well, I finally had an excuse to get the smoker going and that excuse was Mother's Day, I made my own version of the stuffed pork tenderloins that [MENTION=54669]cfranck1[/MENTION] posted 2 years ago that I've been wanting to try. I bought a 10 lb pork tenderloin and ended up having to cut it in half to even get it on the smoker. Next time I will probably cut it into thirds, or hopefully have a bigger smoker by then. I then filleted it down the middle in order to smash a bunch of goodness in the middle.
Since I trimmed the fat cap off I added back some fat with some butter, I slit the meat and worked it into the slits (after this pic)
The main star of the show was the homemade apple butter given to me by a friend, but I also cut up some red onion for some flavor depth
I also cut up some granny smith apples to go inside
Like I said, the apple butter was the main star, and I spread that all on the inside, next time I will probably use more but I didn't want to go crazy on a new recipe. I then added some 3/4 cooked applewood smoked bacon, because bacon...
Next I piled on the red onions and apples
Then I got out the butcher's twine and tied these suckers together as tight as I could. Then I sprinkled a simple dry rub over the outside
And then onto the smoker with some hardwood charcoal and applewood chips for flavor, the larger half of the tenderloin was too large and had to be curled to avoid the lid hitting it, next time I will probably cut into thirds to be safe.
Once the internal temp hit 140 deg in the centermost parts of the meat I pulled them, look at that perfection!
The meat was absolutely incredible! Next time I think I will use less butter and more apple butter, but for a first attempt I was blown away and so was my family, they LOVED it! Lots of complex flavors, with sweetness on the inside and a garlic/peppery spice on the outside of the meat, it was really damn good!
I didn't get any pics of the slices, but it had a nice subtle smoke ring all around the edge of the meat. The puppies had a blast and thoroughly enjoyed the meat and the company, the second my family left, they passed out
Also, since I had the smoker going, my gf had told her coworkers about my smoked deviled eggs, so she hard boiled some eggs and asked me to smoke them. I originally was going to smoke them with cherry like the last time I made them, but since I had the smoker going with apple wood I said let's try this. Can't wait to taste these suckers tonight!
I'll subscribe to this one, i do a little Q, here is my smoker
And a few butts and brisket
Sent from my SM-G930V using Tapatalk
I converted to electric and I like it. easy peasy.
I was busy the last two weekends.
Ribs 2 ways.
Beef Jerky two ways.
Pulled Pork and sweet and spicy sauce.
Steelhead Trout.
I had a propane one before and the electric is so much easier and not as finicky keeping the temperature stable. It just takes longer to heat up.
The bad side is it is stainless with a window so you have to really clean it out each time instead of letting the flavor build up. :eyebrows:
In my BBQ world we say "Friends don't let friends buy electric smokers". You will never get the true flavor you can get from burning sticks. I enjoy the process as much as the food
Of course, YMMV and with all due respect :)
While this may be true, an electric smoker is better than no smoker, and the consistency provided by a thermostat and electric heat-box is handy.
Sent from my Pixel XL using Tapatalk
agreed
There are devices that can be put on many charcoal smokers that enable a set it and forget it cook. A probe is inserted into the cook chamber that regulates a fan to increase O2 to fuel. I used to punch in 275 and it would stay there within a few degrees of set temp. BBQ Guru is what I had.
I have a creekstone prime brisket on the way and will be smoking that Sunday, likely do a few racks of BB's too.
What about a pellet smoker? Technically they use electricity to ignite the burn although after that, the temp is controlled via the augur and airflow (fan).
A coworker of mine has a Daniel Boone smoker from Green Mountain and he swears by it. I've tried some pulled pork he made with it and it was pretty good.
We see a lot of "pellet poopers" on the BBQ comp circuit. They do very well and can maintain temps very well.
With my stick burner, (Shirley Fabrication) I have to tend the fire, usually adding a stick or so ever 45 minutes.
Until now I've been using a regular ole' Weber 22" kettle grill along with an Adrenaline BBQ Slow 'n' Sear accessory. It works *reasonably* well at maintaining temperature over a long period of time but it's certainly not perfect. 3-2-1 style baby back ribs turn out great, but they do require some monitoring over the course of an afternoon in terms of watching the temperature. Usually okay, but since Weber grills aren't insulated I have to be careful when the sun moves across the sky and starts shining directly on it over the course of the day. That makes the temps go up.
The pellet grills make this a no-brainer.
I have a confession to make: I recently started making BBQ ribs using an Instant Pot. They are like 80-90% as good as the real deal but with 10% of the work and the time required. That's a win in my book.
Surprisingly the electric smoker adds plenty of smoke. You just change out the chips every 4 hours if you are doing a long cook.
If I want all wood and smoke I have a full Santa Maria Pit.
It gets lots of use as well.
I've also got a Slow 'N Sear and just bought the Drip 'N Griddle pan. I bought an electric smoker some years back but it's been parked at my buddy's house and I plan on leaving it there. My first smoker was a Smokey Joe that I built and they're cool looking but a ton of work. I've had the Slow 'N Sear for a couple months now.
I've also found that keeping temps can require a bit of oversight but not nearly as much as using the snake method. It seems that the more you open the kettle the more you end up having to adjust the vents to get it stable again. I'm thinking from now on not spritzing unless it's a shot from the top vent. I also foil the bottom rack but with the Drip 'N Griddle I won't have to anymore. Also, if I'm doing a smoke that's over 4 hours I'm just going to fill up the Slow 'N Sear all the way. instead of chancing it with a half chimney full of coals.
We did a rack of beef short ribs last week and they took longer than expected because of opening the kettle a few times due to also doing bratwurst the first hour or so. Every time we opened the kettle the meat ended up dropping about 10 or 12 degrees and it took a while for it to come back up.
About 4 weeks back we did a 13 pound brisket (a little over 10 trimmed) and that took 14 hours. The first smoke we did was a chicken and that turned out great.
I've considered adding an automatic blower but with the design of the gold kettles I think you have to cut a whole in the kettle itself and with the efficiency of the Slow 'N Sear I don't think I want to bother with it.
I've also got an InstaPot but was weary about cooking "BBQ" in it but seeing that you have some experience with real smoking and say it's comparable I'll definitely give it a shot. Thanks!
Since I don't have an insta pot, I went with sticks. Using oak and cherry
Sent from my SM-G950U using Tapatalk
Using my sausage hangers on some jalapeno cheddar sausages
Smoked some baby backs on the smoker on July 4th. Flavor was outstanding, but since it was so hot (about 95 deg with 110 deg heat index) the ribs cooked super fast. I usually do a modified 3-2-1 but the ribs were up to temp in literally an hour and a half, so I wrapped them and sauced them and they were ready to eat pretty quickly. Given the smaller size of my smoker I had to do 2 sessions, but both sets came out fantastic.
Membranes removed and oiled up
All rubbed and ready
On the smoker with lump wood charcoal and cherry wood
All sauced up and ready to eat :yum:
Dat smoke ring though :eek:
And of course when eating ribs or anything that I smoke, I always have an audience
Also, we made a Red White and Blue Caprese Salad with fresh home grown tomatoes, and fresh home grown purple basil from my garden right next to the smoker, the flavor was amazing
Also, got this bad boy delivered yesterday, can't wait to break it in!
UPS guy was not happy with me, he was complaining about how heavy the box is and how it was in the way on the truck the whole day. Then he *****ed that it was tagged for team lift but when I offered to help him he told me that I couldn't help move the box. So I watched him struggle to get it down and onto the dolly. At least he got it up into the garage without damaging it.
Can't wait to open this baby up and season it!
Got the new smoker all setup, had to do a couple side by side pics to show how much bigger the new one is
It's so big that the old smoker can fit entirely inside the new one with the lid closed
With the lid on, you can see it's still in there
Funny stuff
The 22.5 WSM is a beast and will do some awesome Q. I had two 18's and a 22 before i sold or gave them away.
AndiGarage
