97BlackAckCL
Elite Member
Flake is what? You touch it and it kind of flakes off?
Sent from my LGMS428 using Tapatalk
Flakes shown here, once the meat can separate in solid chunks
That is proteins from the fish, it's good for you. Once the salmon starts to flake at all, it's pretty much done. Usually less than 10 minutes depending on how hot it is.
I prepared the Apple stuffed pork loin and I'm going to smoke it tonight. I'll post pics and video of the build-up and smoke later.
Do you guys smoke it on a pan or just let the drippings drop into a drip tray?
Also do you flip it over like in the video?
I'm using an electric smoker and the firebox is internal, but diffused by the water pan between the cooking grates and the firebox.Sounds good!! :thumb:
I smoke it right in the pan like my pictures..
No, I don't flip it because I have a side fire box on mine. If your fire is in the grill, I probably would so one side doesn't burn to much..
I might just cook it on the grate and allow drippings to fall into the water pan and make a gravy from that.
It will probably cook faster if not in a pan, but not much faster I suspect.
If you use a temp probe, where do you insert it? Top loin or bottom. I pounded them pretty thin...
Sent from my Nexus 5X using Tapatalk
How did that ruin it? If it's frozen it shouldn't be bad off leaving it out overnight, maybe room temp at worst.
What wood are you using to smoke with?
The last one was apple for me.
I used cherry the first time I did it.
Liked both smoke flavors.
I had pulled it out the morning before, it was thawed by that night, then left out overnight. it was completely room temperature for idk how many hours, didn't want to take the chance.
I think I became a smoking master overnight, got two smokes under my belt. Both of them came out amazing, I need more wood flavors so I can experiment. I did chicken halves last night that were flawless.
I don't think I will ever go back to regular grilling, except carne asada and steaks maybe.
A king is born.
A king is born.
thanks for the great advice, I used oak on pork loin and the bone in chicken halves, that's the only wood I have right now. What is usually recommended for pork bbq ribs. I was thinking maybe apple since I marinate mine in apple cyder with some lemon juice.Congrats on your early successes :banana: always a good way to start something new.
You may find that it won't matter what wood you use if you over-smoke, so you should experiment with how long you smoke a particular meat vs overall cook time.
A rule of thumb that I follow re wood is the lighter the meat, the lighter the wood. Meaning, chicken and fish and some pork like loin with fruit wood and the meatier the meat with darker woods like hickory or mesquite - go very sparingly with mesquite, it can be overpowering.
I tend to use either hickory or apple/cherry wood for most dishes following the guidelines above. Good luck, and welcome to the smoke club :cowboy:
I'll have to look for Orange wood, thanksTry orange wood, it is awesome!!!! It gives a light/slight citrus flavor. Pairs well with other fruit woods and chicken and pork. It's a new personal favorite of mine.
