Kudos to you for almost running out of gas and potentially clogging your injectors with the crud at the bottom of the tank! :bigok:
You should have found a gas station located on a short block & go around and around to see if you can get it down to ONE.
i've also hit zero but again with no proof...that's just the normal life of a college kid i suppose haha
Correct me if I'm wrong, but don't modern fuel pumps use the fuel as coolant, so that running low causes them to run hot and shorten their lives?...
