Before & After: Stock / Leveling kit / KO2s
ad_robotics
Just put some new KO2s on and thought of sharing the experience :)
Stock / Front 1" spacers / 32" KO2s.
Based off of the this thread, the largest tires I could fit with a minimal amount of lifting are 32" KO2s with a 1" front lift. The post contains info on other configurations so it is worth checking out.
1) Stock w/ 31" tires - they were getting old so they needed to be replaced.
2) Front 1" spacers - Daystar 1" front spacers, note that the spacers are 1" thick but the net lift is ~2". That is because the front struts connect to the middle of the lower control arm, meaning that an increase in strut length will push the tires down by about double that amount.
3) 32" KO2s - lots of people seem to recommend them, seemed like a good choice for an upgrade.
Measurements from the ground to the wheel well:
* Stock w/ 31" tires: front 86cm, rear 92cm
* Front 1" spacers: front 90.5cm, rear 92cm
* Front 1" spacers + 32" tires: front 91cm, rear 92.5cm
PRWhite
