Bent electric antenna mast
SavedbyHim
So question is can just the mast be replaced? If so what do I buy and how difficult of a job is it to replace. If the complete antenna with motor needs to be replaced I would probably buy from a scrap yard. But if that is the case I have been told that the fender needs to be removed? Too much work for a lazy rookie shadetree mechanic with limited mechanical skills? I do have a couple friends that I could get to help if necessary.
Thanks in advance!!!
What year? There are a few write ups kicking around for 1st and 2nd gens. The process is different between the two. You only have to remove the fender LINER to access the mounting bolt.
DionicioLives
