Best aftermarket UCAs with no lift installed.
rasber3140
I am looking to replace the factory UCAs with aftermarket ones. I have a TRD Pro with the only suspension mod being the Toytec 1 inch coil seats. Most of what I have been reading says that the UCAs are recommended for 2 inch or greater lifts. What UCAs would yall recommend if I do not have an aftermarket lift installed?
I recommend none..leave it as is
+1 ... Don't replace them. Keep the truck as stock as possible. You'll be happier in the long run.
Also if you need service later it's easy to get OEM parts no matter where you are. Imagine trying to get an aftermarket UCA replaced in bumbleville.
I'm planning to keep my lift within the factory UCA (if possible). 2in should be enough for my needs and the OEM UCA can be fixed anywhere.
Sent from my SM-G930U using Tapatalk
ghengiskhan
