BEST Dash/Console/Glovebox/Interior Accessories!
I wear all the hats! I have suppliers that cut and mold the parts here in Denver. I own the business and do all the design. I am always open to new ideas and solving common problems. PM me if you have something in mind.
Due to this thread, I ordered my Salex.
Boom!
Missed out on the 10% but I can handle the extra $1.50. Sure beats fishing around while trying to drive. Now that I see everything organized I'm wondering why it was so hard to find things. Time to get more stuff!
I ordered a Salex Organizer & I'm all excited to get my console organized and stuff. And stuff. [emoji13]
It will need the ends cut. It cuts well with any power saw. You will have a hard time with a Dremel getting a clean edge. Others have asked the same question. You might search and see what others have done. Good luck!
I emailed and had this exact answer in my inbox by the next morning so great job from Salex. Big mistake on my end for trying the Dremel anyway because it was a disaster. I'll end up ordering another one because it fit great before vault install, and it's currently a mess in my console. The cleanup from the sanding spray has taken longer than the install of both if I would have done it right the first time.
Ordered the Salex and thank you for the $1.50...It will be used to buy gum to stick in one of my new cubbies when it arrives!
On a side note...Has anyone added a thermometer to show the temp inside the cabin? I am looking for one to either cover or fit into the hole next to the aux port...If I find something I will post... I know it may sound odd, but I wanted a trail but really miss setting a temp and going with it. Apparently you cannot easily swap out a limited A/c cluster
~Mike
Tuck the little divider in the upper right of the picture behind the vertical tab of the console. It will square everything up and improve the fit.
Bummer! When you get it dialed in maybe you can start a thread for others wanting to install in the console vault. Dimensions of each piece would be great.
I might have told you this a while back but I would practice on cardboard. Cut it with a box knife to get the exact fit, then cut the plastic with a power saw.
Just installed! Thanks [MENTION=133641]Salex[/MENTION]
What a simple yet highly useful mod! :cheers:
MB
I'm going through this now, but lack a saw �� The vault gives up quite a bit of space. Thanks, Captain Morgan.
Try doing what Salex told me and tuck the front partition behind the vertical tabs. Straightens it out a bit.
Thank you! That helped, the center divider in the back is angled to make room for a pouch of various tools.
MB
Thanks Guys
Thanks, mine should be there when I get home tonight.
