Best flex pictures?
My weak submission, I just want to belong. :peep:
TS0A6296_zpsbnyhucci.jpg~original
TS0A6298_zpsz8odd6fi.jpg~original
TS0A6303_zpszvvfpqnh.jpg~original
ICON s1 setup with 890s, 285/75/16 Dynapros. Still haven't done anything about sways or bumpstops.
New Bump Stops installed today. Not out 4Wheeling, but just edge of my driveway.
47" from ground to Wheel Well.
20160405_112057_zpszgsjexr0.jpg~original
20160405_112038_zpszentkfbp.jpg~original
Updated!
99 Tall Coils
KYB monomax front struts (I want Bilsteins with more travel)
1.5" rear lift spacers
LC rear shocks
Stock extended bump stops in the rear
No sway bars
Over the summer, I will be working on getting more out of the front
I already posted pictures from this spot in my build thread the other day, but I'd like to add these here and point out whats going on with my suspension. Im running stock land cruiser coils and shocks in the rear with 285's. I got out and measured my shocks and found that the passenger side is 1.5" from full compression and the drivers side is 1.375" from full extension. My stock bumpstop isn't even close to touching the axle, which I need to address. My passenger side tire is about 1/8" away from rubbing the rear corner of the body (which I've already trimmed a lot, as well as rolling the fender lip under). So currently, my tires are limiting my up travel and I can't even use the last 1.25 to 1.5" of shock travel that I have available.
It makes me wonder why more people don't run extended travel land cruiser shocks. Unless you're running a body lift with 285's, you can't take advantage of these shocks full travel. And anyone running 315's is going to have even more up travel limitations and the resulting wasted shock travel.
mostly because the valving is far too stiff.
Other side stuffed into the bumper, which got cut back when I got home.
Just a spot close to my apartment trying to stuff my 35s.
Year: 2002
Tire Size: 315/70r17 Goodyear Wrangler Duratracs
Lift: 3" Suspension Lift (Toytec/Eibach front lift springs, OME 890's, 00-06 Tundra Bilstein 5100's all around), 2" Body Lift
285/75/16 Kenda M/Ts
881 front coils, 890 rear coils
Maiden voyage. Went to big levels in VA, wasn't too bad.
285/70/17 BFG's
Tundra/LC on 5100's
OME 890 rear
LC shocks
99 talls up front with KYB monomax struts
No sway bars
Toytech ultimate
super flex rears
600lb fronts
Sway bars connected
265/75r16 BFGs
Not full droop or compression but there she is.
alexaturner
