Diver brian
What's the best option for the "nicest ride"???
I have 4 crawler upper ball joint spacers 1.5" and OME 901 rear springs. The cool thing about this way is that you can turn down the front torsion bars a lot and soften up the ride in the front dramatically. The rear stiffens up a bit but I have no overall complaints. You can generally use stock shocks as well to my knowledge since it's only adding like 1.5" of overall lift. (I used procomp shocks but finding the right eyelet sizes were a pain) Then 33" tires are also possible. All in you're less than $500 for springs ($180) spacers ($100?) and shocks ($200 for mid grade). Enough left over for 4crawler's panhard correction bracket if desired.
One note if you go with front ball joint spacers is to get some taller bump stops for front droop. This prevents binding of axles when at full droop. Didn't take much for me. Only needed like 1/2" taller bump stops. Like $15 or something. Cheap insurance.
I like my ride quality. Even with heavy duty rear springs it isn't too stiff at all and I know I can load the piss out of it if I need to.
These are 32" tires but I'm fairly certain 33" would fit as I ran 32" prior to the "lift" for years.
sick ride man! tell me where you sourced your taller bumpstops, bonus points for part numbers! off-topic - where is your build thread?
the downey kit is most excellent. i dont run it, but people i know do.
comes with everything you need (no shocks), and i want to say for around 180 bucks.
+1 for Downey kit. I have it and it rock solid.
Thanks for the info 4Reak. I will pull a spring out this weekend and take a look at it. Hoping the MOOG’s will work. Might not get it completely level but can’t afford to get OME springs right now.
