Best lift for under 500
Rishi3
I have an 07 sport and want a 3/2 lift for under $500. Trying to stay away from spacers. Don't off-road much but do nonetheless.
Cant help you out with an 07. I have done a ton of research for a Gen 3, and that is not even close to what it will cost for that much lift. For a Gen 3 there are all kinds of "problems" that start happening and the cost goes through the roof "correcting" things.
If your current suspension is not blown, I know you said you don't want spacers, but its really proble the best route.
Front and rear Bilsteins. Adjust the front to 2-3" and throw on your choice of rear 2" lift spring. About as cheap as you would want to get.
Bilstien 5100s + rear spacer (or rear springs)
Or... check the classifieds. There's always somebody (like me) trying to get rid of their old suspension stuff. Can usually find some decent deals.
I know you said you don't want to do a spacer lift, but I'm pretty happy with my Daystar 2.5/1.5 lift. It cost $130 and I did the installation myself. No need to touch the XREAS, assuming it's still working. Looks good, rides like before, and works well for moderate off-road trails.
Spacer lifts are not for the hard-core offroaders, or for people who drive hard and bottom out their suspension regularly. For the rest of us, they can work well.
If you go as high as 3" up front, you'll likely need aftermarket UCA's to get your caster back to where the vehicle drives well on the highway. That will add another $400 to your cost right there, so stopping at 2-2.5 will help keep costs down.
Spacers are fine for your application. You can prob purchase and have a Daystar 3/2 installed for under $500. I ran spacers for a little over 100,000 and had no issues at all.
Otherwise, stretch the wallet to 800-1000 and you will add a couple options: before install.
Would adding spacers reduce my travel?
Sent from my ZTE B2017G using Tapatalk
Not necessarily. The Daystar lift is a "tophat" lift and will actually increase down travel. That's not necessarily good, if down travel increases to the point of locking up the CV joints. About 2.5 inches of lift is the limit for keeping the CV's out of trouble.
Up travel is also slightly increased, and is limited by the shock compression instead of the bump stop. This isn't a problem unless you are in the habit of bottoming out hard, in which case you can bend the shock.
For these reasons, hardcore offroaders are better served with achieving lift with aftermarket shocks and springs - the suspension will be more robust and take more abuse. However, if you are willing to drive gently, the spacer lift will take you most places you would want to go. I've been on "5 rated" roads (Traildamage.com scale of 1 to 10) without problems, but I drive slow and easy.
I decided to go with ome front coils/springs for 500 and then a 1.5 spacer for the back for 100. Total is around $650
That's not under $500! You can do springs front and rear no problem for that price and stay away from spacers!
