Best mods to increase MPG
Best mods to boost MPG
  • Exhaust
    Votes: 36 13.6%
  • Intake
    Votes: 48 18.1%
  • Chip
    Votes: 16 6.0%
  • Smaller Tires
    Votes: 19 7.2%
  • Tire Pressure
    Votes: 110 41.5%
  • Fuel Type or additives
    Votes: 8 3.0%
  • Spark Plugs
    Votes: 12 4.5%
  • Gears
    Votes: 16 6.0%
  • Total voters
    265
CJ3Flyr said:
As much good (and amusing) commentary as there's been thus far nobody has mentioned leaving it in 'N' at long lights.
I do two things that help my mileage noticeably, 40PSI in the tires and I check them often. The second thing is once I am sure the car behind me is stopping I put the transmission in neutral (if I think I am going to be stopped for 20 seconds or more). I know it helps because the tach jumps up as I put it in N and immediately thereafter the ECM reduces the fuel and air reducing the idle back to the target RPM.
Fill the tires; accomplish long stops in N.
This should kick-off the next phase... Does it save gas to shut the engine off at a red light or does it take more to shut it off and restart? Hehe, this oughtta be good.:bash: :biggrin2:
I don't know about anyone else, but when I put it into neutral at a stop my RPM's go up. If the RPM's go up I have to assume that more gas is being used. I also thought that the air/fuel mixture was kept constant by the ECM. I have to admit though I don't know squat about these things I'm just going off of what I perceive things to be.
"Be an informed customer."
I love it, that sums up exactly why I found this site. I want to do great things for my runner, but I don't want to harm it.
Thank you for asking to post what items I found, as I'd love (and be very appreciative on feedback) to hear what others actually know about these possibly "snake-oil" items.
This is the first one, the regulator/chip.
http://cgi.ebay.com/ebaymotors/Toyo...ryZ33553QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
And I was thinking used in conjunction with this, the FloBlade.
http://cgi.ebay.com/ebaymotors/Toyo...ryZ42604QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Please do not yell at me, I'm learning...and again, just tying to do right by my Ruffian, but also improve performance.
Once I've saved up, I'll do the expensive mods with the intake and exhaust.
I do notice a difference in using the gas that's higher in octane than the 87. Not much, maybe only 40 miles, but that is two extra days of work commute for me.
Thanks for your time----Melinda:biggrin2:
Melinda,
My 2 cents is that the FloBlade won't do much for you and unless it fits perfectly it may harm the engine. The harm would come if the install of the FloBlade caused something on the filtered side of air filter leak in dirty air. The swirling motion may help an engine of a different design than your 4Runner. Carburetors and what's called throttle-body-injection may benefit from stirring up the air. On your Toyota the fuel doesn't get into the airstream until the air is right next to the intake valve, which is pretty far down the line. In all likelihood all swirling would be gone by that point in time. I think all it would do for you is restrict the airflow a little bit and cut into your full-throttle performance. The good news is there was a similar product that wasn
Thank you very much.
I think I'll give them a try for a tank of gas, and see what sort of things change on the runner. Right now, because it is winter, I can't see how telling the computer that the air is cold, when the air IS cold, should make much of a difference. I also think that during summer, when the air is NOT cold, would put you more at risk of doing damage.
I've bought a higher quality air filter from Burtman Industries, and I feel that is the safest start.
Of course, I'll keep tabs on the milage, and I'll post my experiment here. I'd love to read where someone else has done this, kinda like a buy-it-try-it deal they do on the news here in Sacramento. I'll take photos too.
Truth is I don't know. If the box is lying to the engine by 10-15F degrees it may never cause a problem. If it is lying by 30+F degrees it MAY be a problem. The ignition is good, the fuel injection is good it may be fine; I just don
Yeah, as soon as I'd hit 'post', I thought that the one tank idea wouldn't show any results, and that for a true experiment, you would need several tanks.
Tried it last night, and came here to post my experience as wll. My RPM's go up too in neutral.
When you go from Drive to Park or Neutral at a light it is only natural that the RPM's go up. You have removed the load of the transmission and brakes (holding you still) from the engine. Be assured, just because the RPM's increase YOU ARE NOT BURNING MORE FUEL in Park or Neutral.
My RPM go up too... If you watch the tach and listen as you go from 'D' to 'N' it looks and sounds as though the tach may be headed for 1000-1100rpm; the computer then adjusts timing and throttle plate/fuel to hold the rpm at 700+/-. I postulate that the fuel required to idle in 'D' is similar to holding the throttle slightly to create a 1000-1100rpm fast idle. Assuming that my interpretation of the initial rpm rise when you place it in 'N' is correct then it's the computers adjustment that allows the idle to settle at 700+/- rpm and save fuel.
Don't misinterpret, my idle never gets as high as 1000-1100rpm when I shift from 'D' to 'N', that's just my interpretation of what the initial trend would do if the computer didn't step in...
Another benefit is the couple of extra rpm in 'N' allows my A/C to blow a touch colder. (I had too throw that in 'cause I'm so jealous of you guys playing in the snow... Florida does have a few advantages, needing A/C in January is one of them :bigok: )
Maybe I have this backwards, but I thought that with the transmission in neutral that the a/c automatically shuts off if the vehicle is left idling for a period of time.
The A/C shouldn't shut off just because the vehicle is left in neutral (or even park).
Ricky
I agree...the biggest fuel saver is a modified right foot.
When my wife was driving our '97 Runner, we were getting 16 mpg (she's a stoplight racer...), but now that I'm driving it (like an old man), I'm seeing 20 mpg.
How to get better gas mileage? Drive 100% highway miles and don't tow any trailers (which is why my mileage has been in the crapper lately, because I am always dragging toys around on the weekends).
A way to improve gas mileage is to reset the computer. When you reconnect the battery, the computer will relearn your driving style. In the learning phase, go light on the gas.
My average 'total miles' to fill up now shows 390 vs. 336 at each fill up. Weird.
RickyCRX said:
Slow accelerating and 'conservative' driving will not do as much as paying attention and looking FAR ahead down the road to anticipate traffic slowing down. You can do quick accelerations and still get good mileage if you make sure you plan ahead to where you can coast as long as possible and manage your speed so you're not using your brakes very much.
Every time you hit your brakes, you are throwing away money both in pad life and fuel burned to get up to the speed you were at.
So, the best mod is to mod your driving habits... This will also make you a better driver because you will be more aware of what's going on around you.
Ricky
smart advice
Ditto on getting a Yaris.
How that commercial (teenage boy with hot Scandinavian girl, Inga, doing homework in his bedroom when dad walks in) should have been scripted:
"All the boys stare at my Yaris,
they want to play with my Yaris
& get in my Yaris & ride my Yaris all the time.
Ya - they just won't leave
my foxy little Yaris alone!"
:girl:Inga Commercial
johnnya
