Best Rear Suspension to Match Front Coilovers
Atrox Caeda
I just picked up an '01 SR5 4Runner a few months ago and have been deciding on all the mods I need to do to make it trail worthy. Obviously suspension is on the list and as it turns out whilst checking Sir Craigslist one day I came across a set of Fabtech Coilovers for a very nominal price. Checked them out, super clean, good to go. Now, since my original plan was to go with the OME entire kit, there is no longer a "Set" which was developed together. So I reduce my overall question to this: Does anyone who is running a front coilover setup have a preference for a rear suspension set up and if so, for what reason and what is your overall intended use, ie. Desert running, crawling, etc. Also how much additional weight is on your rig and your experience with changing or adjusting that weight and the suspension you are/were using.
Thanks!
Thanks!
How about you tell us this and we tell you the right setup.. that sounds easier.
If its any help to you, im running the adjustable fabtech coilovers in the front with it setting at 3". i went with the OME 906s in the rear but I wasnt happy with the height it was sitting at so i added 1.5" spacers. now it sets at 3.25" in the rear after it all settled. if i was gonna do it again i think id go with the OME 891's instead of what i got set up.
heres how it sits with 265/75/16s
H.Sikina
