Best replacement speaker setup??
RCS24pro
I was just wondering if anyone had any suggestions on what a good replacement speaker set-up would be for my 99 4runner. I just bought it a few months ago and am looking to replace the stock speakers and maybe the stock tweeters as well. I've read about people getting brackets to install 6.5's up front and the rear...I wanted to know if this was easy and practical to do? Also, I was planning on running the speakers on one amp while running a sub (maybe 2) on another amp. If anyone has any suggestions for me I'd appreciate it. Thanks.
Ryan
I have all Alpine DDrive components. Great speakers and I've had them for many years.
The rear speakers are actually 4". I somehow squeezed in 5 1/4. You have to modify the plastic housing a little in the door panel. There is a ridge on the rear mounting surface which prevents just any 5 1/4 speaker from fitting flush against the surface. The factory speakers are not your run-of-the-mill auto speakers and were obviously designed with the abnormal surface in mind.
However, most aftermarket speakers don't take such things into account. The front wasn't so bad, but I still had to use silicone sealant to be sure that there was no air between the speakers and the plastic mounting surface. I think Toyota wanted to make it difficult to replace the factory speakers. Of course, you could just make your own custom mounting surface.
The 5 1/4's I installed were separates and here is where I mounted the tweeter and painted to match:
Now, if you want to go for a BIGGER speaker, I did help a friend install JBL 6.5's in the rear.
To do this we took the OEM 4" plastic mount and used it as a template against a sheet of 3/8" MDF. We also glued-n-screwed a short piece of PVC conduit on the front and back of the MDF as a mounting standoff similar to the OEM bracket. With a little foam weatherstripping and black paint it looks factory. There was very minor plastic trimming necessary to the backside of the doorpanel. No a big deal. We then flush mounted tweeters in the C-pillar plastic trim above and behind the passenger's heads aiming and crossing forward. The external crossovers were easily mounted behind the plastic trim.
The installation took a while, but it looks very nice and the imaging is very good. I would recommend to anyone doing a speaker upgrade to look at separates w/ the tweeter located up higher.
Hello! My girl got an 02 this weekend and I love it!
I'm going with alpine head unit and the 6.5 in alpine type r's in the front, type s 5 1/4 in the back powered by an alpine 4 channel amp, couldn't tell you which one yet. I'll post some pics when its done!
