best road paint remover
oreg
any suggestion for best road paint remover
The road yellow paint splattered up on the underside of my rig, what do i use to remove the yellow paint without ruining the finish
thanks
oreg
Clay bars work great for over spray and may help with splatter. Worst case scenario you can use lacquer thinner sparingly. I would try some elbow grease and a sponge first though and quickly. The sooner you remove it the better
Traffic Paint
Try "bug and tar renover" which is usually a proven blend of solvents that are safe for auto finishes.
If the paint is not heavy and only overspray, than the clay bar suggestion is the safest route.
For truly heavy build-up then straight solvents may be required.
Removal solvents depend on whether the paint is water or solvent based. For traditional solvent based paints try toluene or VM&P naphtha. Toluene is a better solvent for the coating but VM&P is safer for the vehicle paint.
For water-based coatings, try isopropanol or the above mentioned bug and tar remover.
Be very careful with lacquer thinner since this is normally a "stronger" blend of solvents such as aromatics, esters, and even ketones. This can soften and/or remove most automotive coatings if left on too long or rubbed too aggressively.
