Best stock alternator replacement option
sctrsk
Gents:
Bearings are going on my OEM alternator and the squeaking drives me nuts.
I'd like to replace it with an equal-to-factory quality option and I don't want to change it to the cs144 alternator (I have literally never once had a power problem and do not intend to add anything that would necessitate it in the future).
What options do I have here? I've had way too many issues with parts from any of the box stores (including NAPA) to buy a generic part. It would hurt to pay $400 for one from a dealer, however.
Does anyone have any suggestions for a quality reman OEM that is as reliable as this one was?
About 2 years ago when my original alt died of old age (310k miles), I bought an oem alt from a junk yard on ebay for $50 shipped. It had around 90k miles on it they claimed. When I received it I replaced the brushes and cleaned it up before installing it. The minimal wear on the slip rings was consistent with around 90k miles as advertised. Has worked perfectly since! You want to avoid rebuilt alts like the plague!
Gents:
If the alternative works fine then replace the bearing it's 36 bucks 9009910199.
OEM all the way. My trucks got a crappy parts store reman on it now. I plan to find a stock low mileage alternator and re-brush it myself. Heck, I may even replace the bearings if I can find Koyo or Timken bearings for it. Otherwise, I will end up with a CS144 upgrade if I can't find a decent rebuildable OEM alt.
I had to put 2 Alts on my Land Cruiser, I really regret returning the core to Oreilly, I should have kept it and rebuilt it, because the Oreilly Ultima brand last almost exactly 1 year. The free replacement is still going after 2 years, but I don't trust it.
Denso reman period.replaced my 18 year old original denso unit in 2012. Do not even waste your time with Chinese crap from Autozone or Advanced.
the link I posted is only 193.00 from toyota parts deal
there is a core charge of 75
You are a saint, thank you!
I know I should rebuild it, but its one of those things where I have 4 motorcycles, two of which need total rebuilds, have to pull the motor on my boat, have to paint my 87 535is, and am looking to buy a house (to keep all the aforementioned trash lol) so if I can spend a little extra and save myself a weekend, at this point its looking like a better option.
I feel you brotha. I am the same way.
mtbtm videos make it easy if you just need brushes..
bought a NEW CS144 alternator, but decided not to install and just did brushes on my stock one.
That one has gone another 20k with no issues. I also now have a spare Toyota denso that I got and one of these days I will rebuild that with bearings and brushes.
So I got a CS144 new alternator and adapter harness id sell...but only in Alaska...shipping to the lower 48 would be not worth it
I’m a little confused on the GM Alt reliability. Like (I Think) DOC said, his Alt mod has lasted years. I’ve never had a 1 wire GM Alt fail before the 200K mile mark. A few members get junk rebuilds and the CS 144 is now junk? It’s no different than a reman Junk Denso Alt rebuild.
I would hate to think that he thinks he is a product of bad info and every time he sees a thread on the upgrade and how it took a crap 3 months later he feels guilty.............
Reman shops in bulk only replace what is bad. It only gets new brushes if that was what the failure was. Or the rectifier, or the regulator......
I personally have no problem going junking for a CS144 Alt and replacing the brushes and seeing how long it lasts. Especially if it will push 80a at idle. I’ve had two CS alt’s last 200k miles with no issues. Plus an older SI that lasted over 160k miles, and it’s still working as far as I can tell. The old CJ7 is no longer mine.
I’ll admit that the Denso is slightly easier to rebuild. Mostly because the GM requires soldering and the Denso is screws.
I really hope the CS144 bashing isn’t just regurgitating a few bad units and now all have become junk.
Just for the record, all you all buying a reman Alt for your Toy and having it fail....it’s not a new alternator with ZERO parts available. Figure out if it’s the 70a or the 80a and buy the parts from Toyota to fix it. (And that’s all but as simple as looking at the brush assembly and you know what output you have).
Turning in your factory Alt as a core did not screw you for life. Just fix your reman Denso Alt by yourself and move on.
Tx470
