Biggest tires and Wheel Well mods???
bulet2hart
I have a 2004 Yota 4Runner. Stock 17 inch rims. My back wheels have 2 inch spacers. Has anyone done easy mods to the Wheel well and fenders to allow bigger sizes? if so can ya help a fellow owner out with pics?
How big are you talking? You can run relatively skinny 32's with almost no modification (255/75r17). When you move up to 33s on stock wheels you def need a lift and spacers front and rear to avoid rubbing on the upper control arm. You will also need to trim the inside lower front bumper and ditch the mud flaps. Depending on the tire you may also need to do a body mount chop, search that term for more info. Bigger than 33's, anticipate all of the above but even more trimming, body mount chop for sure, and probably need an aftermarket bumper. A body lift in the 1.25-1.5 range helps with 33s and up.
Jhunt
