Bilstein 5100 adjustability question
Brobertson300
I had my new struts installed on my 4Runner today and they put it on the .85 setting and I think it would of looked better on the 1.75 setting. Do I have to remove the whole strut set up to adjust it or is there an easier way? Can I compress the spring and do it?
i wouldnt try to do it on the vehicle. you theoretically could compress the spring, hold it up, and move the clip. however, if the compressors fail and your fingers are in there trying to move the clip, thats no good. best and safest way is to remove the strut assembly and disassemble
btw, where in connecticut?
Yeah, don't try it. It's not worth the risk. For the time it takes to pull the strut out (20 min after its on stands), it's much safer and better to just pull it.
I agree. Not worth the risk using spring compressors in there but you could follow the "no spring compressor method " and technically keep the strut somewhat in place to move the c-clip up.
Thanks for the advice! I'm on the shoreline - Westbrook, CT. How about you?
this would be my first step, see if you can do it this way before taking it entirely out
I'm on the opposite end, right up on the border by springfield. granby-suffield area
I'm not familiar with this method. Do you have a link for instructions? Or do you have somewhat simple instructions you can explain?
seltzernator
