Bilstein 5100 help
Duke562
So I had had the billsteins set at 1.75 for two months recently every time I turn left there is a popping noise . I thought it was a bad ball joint as there was visually needed replaced . I replaced with light racing UCA on bob sides . The noise is still there , I had toyota inspect they had it for two days and said it is the UCA however this is not true because the noise was there with the factory UCA . Anyone have any other insight . They also checked all chasis bolts and suspension bolts for tightness . And they did not see any other issues visually
Did you grease the bjs and polybushings on ur upper control arms? Check your tie rod ends and lower bjs too. If it were a problem with your shocks or springs you would hear the noise everytime the suspension compresses and rebounds. I'm betting its your tie rod ends though.
erinobr2000
