Bilstein 5100 shocks
jman11788
Member
I'm looking to purchase some Bilstein 5100 series shocks in the front no rear I have the hd's in the rear. I was wondering where can I find these shocks without the coil strut assembly? I've looked everywhere and can't seem to find them without the coil strut assembly.
toyteclifts.com or suspensionconnection.com
suspension connection is cheaper and usually have an extra discount if you spend over $200
Ok thanks do they not have this for the 4runner why does it have to be from the Tacoma?
They have them specifically for the 3rd gen, so you wont have to search Tacoma.
NewMex was just telling you that if they didn't specifically have them for the 4runner, that the Tacomas of those years would fit too.
Really? So when you buy the parts separately you call them a strut and a coil correct?
Then when put together it is a coil over shock? I have heard plenty of times that it is a strut. If anything you should call it a coil over strut since it is not a shock
(in the front).
Eh...a strut IS a coilover, technically. A strut is just a shock absorber with a spring perch mounted on it. Some folks don't like to use the term strut when describing suspension because it isn't very manly.
The main difference is that strut suspension has no upper control arm and the strut is basically doubles as the spindle and the shock.
Pic for reference
Hmm... Can I shed some light?
Strut on the left, shock on the right. Notice the difference in the lower end of the strut on the left, and shock on the right.
The point is, putting a spring around a shock does not make it a strut. To be a strut means it not only controls the up and down movement of the suspension/tire/wheel combination, but also controls the lateral movements of the upper part of the knuckle it's bolted to.
Shocks are not made stout enough and do not have mounts built into them made for controlling the lateral forces inherent in a suspension with no upper control arm. Struts do, spring mounted on them, or not.
A shock is one unit. A strut is a suspension system comprised of numerous mechanical parts. You folks do make me laugh.
