Bilstein 5100's ??
Jason4runner2
Read many posts and still have some questions.
Planning on putting bilstein 5100's in front possibly at 1.75 with 1 inch spacers in the rear. What will be the true height I will get with this setting and what's the largest tire I can put on without any rubbing?
Thanks in advance! Too much info on this site its making my head hurt!
Yeah, the site can be a bit overwhelming at first, but keep at it and you'll find your way.
5100s at 1.75" with 1" rear spacers is a tried and true combo. Not sure what you mean by "true height," but you can assume that's about how much lift you'll get.
You can go for 285/70-17 tires but will likely get a bit of rubbing that can be solved pretty easily with a bit of mudflap trimming and a fender liner re-position.
Did you see the 5th Gen tire fitment guide? I'm too lazy to search for the link, but that doesn't mean you have to be ;)
There are a bunch of long threads to study on this. I decided to go with the 6112/5160 with Daystar 1.5 since I plan on adding weight to the front, eventually. Getting them installed this coming Friday.
Most of us had to read all the lengthy threads when we researched for the right lift as well, we all survived. It's good for you, start the reading. You'll be more knowledgeable after the fact.
Your answers are out there. You just can't be lazy and read through the threads because when you ask, most people will remain silent since the info has been repeated over and over.
I'd sell you a 1" Cornfed spacer set for the rear for a discounted price. Had it installed last week and not happy with my results(reverse rake due to 2.5" front spacer). If any interest.....send me a PM
