Bilstein rear 5100 shocks upper bushings
DPR64
Finally throwing on the rear bilsteins from Wheelsers and found the upper bushings to be confusing... 2 rubber bushings and 3 different rubber bushing washers...
2 of them are somewhat similar although one is a dark steel and the other is a bright steel, both have the same diameter hole in the middle.
The 3rd steel washer is a bright steel and the hole in the middle is quite large, larger than the other 2.
What order do these go on??
1. Dark steel, rubber, bright steel
2. FRAME
3. Rubber, bright steel with larger hole, nut?
Or in this order?
Dark steel
Rubber
Bright steel with larger hole
FRAME
Bright steel
Nut
Tx470
