Bilstein Shocks?
Will not work in this case. Definitely wont work in the front. And unless your zuk mod netted you a 3-4" lift over factory in the rear then it will not work here either. I run 5100's in the rear and it is pretty clear that a truck with a lower height will be bottoming out the shock under compression.... no good.
just go w/ the yellow body.
I think the shortest travel 5100 is 10". Stock height and a 10" travel shock is to long.
Thanks guys! I appreciate the replies. Just an fyi jet.com has the 5100s for roughly $60ea. Thats with a %15 coupon code you get when you sign up.
Do they recommend or provide a larger profile bump stop with the shocks/lift? If not, the suspension is going to bump to the same spot during full compression regardless of lift. Over extending is the issue with lifted vehicles. If they don't say to lengthen bumpstops then technically it should be compatible on stock vehicles
