BL Bolt Question.
shootmymime
Can someone give the the exact lengths of the 10 bolts that hold the body to the frame? OR. The length of bolts they used plus their body lift height.
I know the longest are the ones in the front. Followed by 6 shorter ones under the doors then 2 in the rear.
Much appreciated.
I want to have all the parts so I'm not running to ace to look and see if they have the bolts. When I'm doing the body lift
I can grab it in a bit
thanks boss,
i went out and pulled 3 of mine. the lengths of stock bolt sizes as follows.
All lengths are from the bottom of the head of the bolt to the end of threads (aka not including head in length).
Fronts 5.5"
Middle 4.75"
Rear 3.5"
Underfire if you could check these against yours.
Im just going to build my own BL following Roger Browns instructions and the exact same grade 8 hardware and UHMW
thanks boss,
Fronts 5.5"
Middle 4.75"
Rear 3.5"
Alright, Mine's a 3" 4Crawler BL with the Grade 8 hardware.
I got 8" for the front 2 sets (Bumper and driver's footwell)
9" for the 2 middle sets (Rear footwell, Rear seatback)
and 7" for the Rear set (Hatch)
Lots of extra hanging down in the 2 middle sets, but I guess there's probably a reason for it.
Jhunt
